Erwin14
#1 Posted : Wednesday, April 21, 2010 9:48:04 AM(UTC)
Erwin14
4/21/2010 12:47 CDT
I have a Kenmore model 17532200 dishwasher. The water inlet allows water into the dishwasher without any water hammer. There is a leak (minimal) at the water inlet (FSP 8269240). I have replaced the gasket between the inlet and the dishwasher wall but the leak persists. How can I stop this leak? Maybe RTV caulk inside the gasket perimeter?
Thanks for your help.
Erwin
#2 Posted : Wednesday, April 21, 2010 6:03:49 PM(UTC)
Erwin,
Most likely there is too much pressure in the water line. Try to close the water shut off valve for the dishwasher slowly turn by turn until the leak will stop.
Erwin14
#3 Posted : Wednesday, April 21, 2010 11:09:07 PM(UTC)
Erwin14
Gene,
My supply valve is a quarter turn ball valve. I barely cracked it open and the leak happened anyway. My tub is made of plastic if that makes any difference. At the present time, I have extended the wiring, drain line and supply line so I can test the dishwasher out in the open to make trouble shooting easier. Any other ideas?
Thanks,
Erwin
#4 Posted : Thursday, April 22, 2010 12:06:42 PM(UTC)
Erwin,
You can try a silicone caulk outside of tub.
Kenmore Dishwasher leaks above motor (Dishwasher Repair)
by stlawerence 5/14/2012 4:08:32 PM(UTC)
kenmore dishwasher leakage (Dishwasher Repair)
by amitdotca 6/28/2011 1:19:44 PM(UTC)
kenmore dishwasher leaks (Dishwasher Repair)
by barneyrubble 6/18/2009 7:48:07 AM(UTC)
Kenmore dishwasher leak underneath (Dishwasher Repair)
by moorek 1/15/2009 10:21:01 AM(UTC)
Kenmore Dishwasher Leak, through front door (Dishwasher Repair)
by mike degn 9/15/2008 11:02:09 AM(UTC)
