Can you tell me the correct connection of the two wires to the start switch terminals when installing my new part? I failed to note which wire went to which terminal when I took the old part off. Thanks.
I literally just goe done replacing mine but I appear to have a different assembly than you do - I had two gray and two red wires to disconnect and then reconnect. The gray ones went into the slots on the right side and the two red were connected together and went into the top left slot. Sorry I can't be of more help.
