kbarnitz
#1 Posted : Monday, April 19, 2010 9:09:58 AM(UTC)
kbarnitz
At the end of the cycle for a large load there is water sitting in the bottom of the tub. This doesn't happen with a small load. I have replaced the belts and the machine is level. Thanks in advance for any help. Kathy
sidfink43
#2 Posted : Thursday, April 22, 2010 4:13:15 PM(UTC)
sidfink43
You will want to rule out a problem with the pump or some obstruction in the pump or the internal drain hoses.
Use this service manual to open it up and check things out.
http://www.servicematters.com/m...6010373%20(16001145).pdf
