When the oven light switch is activated, the oven light does not illuminate- maybe needs new bulb- I can't locate the oven lamp light bulb. Any help is appreciated.
Thnx, Ray
Hy Ray, You can find the complete instructions in the " Owner Manual" (page 40). Here are the break down diagrams for the Jenn Air range Model SCE4340WGene.
Gene, thank you very much, found and changed the bulb. :)
You're welcome. I'm glad you were able to fix it.
