sw1956
#1 Posted : Saturday, April 17, 2010 3:31:45 PM(UTC)
sw1956
Hello ,
The washer is humming when switched on....runs dry and does not let water in.....when filled manually with water will continue cycle wash and pump out.I tried the test cycle by holding in scrub and economy buttons and then switching on. 21 comes up, repressing the buttons display goes to 5 and stays there.
Not sure what to do next ?...was hoping for an error code so I can start to understand the problem.
Also have seen the link to the repair manual but cannot find the manual pdf anywhere.Where can I find this ?
Thanks !
Steve
