This fridge is less than 2 years old and last night we noticed the yogurt seemed kind of warm. Today I stuck a fridge thermometer in it and have slowly watching the temp creep up. Got everything out of the fridge and the thermometer is reading 70 degrees now all the way on the coldest setting. Freezer is working fine. On the top vent there is cold air coming out. Of course it's Sat so I probably wouldn't be able to get any parts until Monday but is there things I can check or does someone know what the culprit might be? TIA!
I wanted to add that we took the panel off the back of the fridge(on the outside) and there was no frost or ice anywhere. The coils on the other hand were so caked full of dust balls that I am not sure how any air could go through them. We cleaned those all up and now we are just waiting and seeing what happens with the fridge part. Any other ideas if the dust wasn't our answer?
