after replacing control board the front lights come on but will not do anything. Will not start
Use the troubleshooting section of this manual to see if you can determine the problem. https://secured.whirlpoo...64beaa/$FILE/Duetdry.pdfIf you are still having difficulty, post with the results of your testing and tell us what caused you to replace the board. Also, it is possible you received a defective board so don't rule that out.
