mckinleyhorse2
#1 Posted : Thursday, April 15, 2010 10:32:50 AM(UTC)
mckinleyhorse2
I have a model RS22CFXT000 Roper Side X Side that is 3 years old. The ice cream will melt in the freezer, but everything else is frozen. Refrigerator is fine. At one point stuff started to thaw, but froze back. I took the back panel off the freezer and there is frost build up at the bottom of the inside coil , but not at the top. There is not enough build up to block air movement. All the fans inside and out are blowing good. I no longer have Ice cream in there and all the meat is rock hard. The current temp in the freezer is -12 F When the problem started I think I had the freezer too packed full to move any air. So I took a lot of stuff out, (enough for proper circulation) but that didn't help the ice cream. Now it is almost empty and has been for a while. The ice in the ice bin will wither away over time. Is this a closed system problem?
Thanks in advance
#2 Posted : Thursday, April 15, 2010 2:23:28 PM(UTC)
Remove the rear cover and make sure the condenser (#3 on the diagram) is clean.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL RS22CFXTQ00 Refrigerator | AppliancePartsPros.com
mckinleyhorse2
#3 Posted : Friday, April 16, 2010 7:11:42 AM(UTC)
mckinleyhorse2
Hello,
I took a look at it and it was a little dirty, but not bad. Air should still have been able to pass through and cool it. Either way, I cleaned it off. My build up of ice is almost 1/4 inch thick on the pipe at the bottom of the coil and none by the time it gets up to the top by the fan.
Thanks for all your help.
#4 Posted : Friday, April 16, 2010 3:36:29 PM(UTC)
Sounds like there is a problem with the compressor. The further diagnostics should be done by a pro.
