I have a Frigidaire front load washing machine model # FTF2140FS1. It will not spin on the final cycle. I replaced the control board and still get a E43 code.I have checked and rulled out the pump. All the cycles work fine in diagnostic mode. I put some towells in the machine and it shook the drum like crazy during the spin sycle in the diagnostic mode.
I believe the problem is either in the speed/motor control board or the door lock assembly, which for some reasons on this model causes the machine not to do the final spin. I mostly suspect the door lock assembly, but check out the wiring to and from it first.
As far as the vibration in test mode, that it is a mystery. Try observing the machine operate with the back off and see if you can determine what is wrong.
