Dishwasher sticks on wash cycle and runs for hours, will not drain soapy water. Cancel and drain is the only way to empty soapy water, the rinse and hold cycle seems to be working ok. What are possible solutions.
John, Sounds like the problem is a bad control module. It might be on recall. Call Bosch before you order the part. - The control module Part number: AP3194844
