ianmcafee
#1 Posted : Tuesday, April 13, 2010 1:02:07 PM(UTC)
ianmcafee
I took the transmission out of my Frigidaire washer because it was spinning but not agitating. the motor free spins in either direction. Once i got the transmission out i checked to see if it would rotate in either direction. it will only rotate in one direction. Should it rotate in both directions?
#2 Posted : Tuesday, April 13, 2010 4:43:35 PM(UTC)
The transmission pulley should move in both directions. If it does not, then the transmission has to be replaced.
- The transmission Part number: AP3892126
