My dishwasher stops twice at the heating delay and will not move forward. This is on the hi temp wash. I have seen similar posts but can't quite figure out what part I need in order to fix the problem.
Thanks!
According to the wiring diagram there are two parts in the heating circuit: the high limit thermostat and the heater. You have to have an Ohmmeter to check them for continuity to pin point a bad part. - The heater Part number: AP4424048
