My washer is starting to leak water down below the tub only in the spin cycle. It is 26 years old machine. I was thinking of replacing all of the seals. Is it worth the time and effort to fix this machine that has worked do well for 26 years???????????? What is the trick to getting the agitator cap off???????????
Yes, the washer will fill and it will run
