Pull the freezwere panel and check if the fan blade is hitting something like ice.
Originally Posted by: richappy  Pull the freezwere panel and check if the fan blade is hitting something like ice. I have the same problem. Just started today. Is the freezer panel that I need to pull inside the freezer or outside on the back?
