Mnell
#1 Posted : Saturday, April 10, 2010 11:28:19 AM(UTC)
Mnell
Dishwasher will not auto advance from one cycle to another and now will not turn off at the completion of the cycle just keeps going on to wash .
Repairman has replaced drain pump motor and cycle control mechanism. Now says that the temperature gauge must be bad but he can not find the part. Does this make sense? Do not want to keep putting money into the dishwasher if problem can not be fixed. Thanks for your help.:confused:
dave piersall
#2 Posted : Tuesday, April 13, 2010 6:49:46 AM(UTC)
dave piersall
i am having same problem. the only i could find out is make sure ur water temp. is 140,and machine is level.after that the only thing i could find that it could be is the control module
