Recently, the transmission > motor coupler broke which I was able to replace. When disassembling the washer, this part fell out. I was unable to locate where exactly it went so I went on with the assembly. The washer now makes a burning smell (go figure) when doing the first load. I assumed I would need the part, if someone could help identify it and where it goes - would be greatly appreciated. Thanks  tedbalog attached the following image(s):
