jeepsjls
#1 Posted : Friday, April 9, 2010 4:31:23 AM(UTC)
jeepsjls
Can anyone help me diagnose what need to be replaced? I have 13 y.o. Gas dryer with No Heat at any point of the cycle. I have tested 63 ohm thru the igniter, & I have continuity thru the Flame Sensor. Everything appear clear around the gas orfice. Short of replacing the valve or the burner assy$$. What else could be checked?
jeepsjls
#2 Posted : Saturday, April 10, 2010 9:22:13 PM(UTC)
jeepsjls
After reading several posts & threads of similar problems, the replies from Gene helped me diagnose my Dryer issue. I was able to fix it for under $40, Thank you Appliancepartspro.com & especially Gene!
Jim
