Side by Side refrigerator. The fresh food side is getting to cold. Will freeze th food at times. Tempature control is set at 2 Freezer 1 fresh food side. Replaced the temp control board no change. Could the Mother Board be the problem......Thanks
This is a classic symptom of a damper control failure.
