Both fridge and freezer were getting too warm.I replaced the compressor start relay and seemed fine for a few days.Now when I notice it's not cooling , I lightly tap the controll panel where the thermostat and lights etc. are it kicks in and gets ice cold again. It might stay running a little longer than it should and if I lightly tap again it will shut off.I was wondering about replacing the thermostat or the main board.The thermostat is alot cheaper. Any help with this would be just wonderful.Thanks
THIS FORUM IS DEAD!!!!!!! |
