The bake element went out the other day so I replaced it with a new one. Now when I turn on the oven neither bake or broil elements heat up. I can hear what sounds like a switch clicking occasionally in the controls / touchpad area. I reviewed the wiring diagram and tried to track down the thermal limiter switch but cannot locate it based on what the wiring diagram shows. Diagram indicates the switch to be a stand alone device inline with one of the power wires in route to the control board. I assume the limiter switch would be the first item to investigate? Thanks in advance for your help!!
Mark
Hi Mark, There are no thermal safety devises for Bake and/or Broil oven functions in your oven. Pull the range, remove the rear cover and check all wires. If there is nothing wrong then, most likely, the problem is a bad oven control board (aka clock). - The part number for the clock is AP3461339 Gene.
