raymondb
#1 Posted : Tuesday, April 6, 2010 7:14:36 PM(UTC)
raymondb
I have been getting sensor error codes after oven is on about 15 - 20 min. The oven then shuts off. Sometimes I even get the msg when the oven is not on. Tried replacing sensor but that did not correct the problem. Any ideas as to what is causing the problem?
