gagglemama
#1 Posted : 15 years ago
gagglemama
Have a front load Fridgidaire washing machine and during the spin cycle it started making a loud clunking noise (like the drum is uneven) and when we took the clothes out they have what appears to be grease on them....any advice???
sidfink43
#2 Posted : 15 years ago
sidfink43
Difficult to say what the problem is because only a visual inspection will tell us what happened.
Here is a service manual that should cover your model. Use it to take it apart (top and back) and see if you can spot the problem. Focus on the tub supports.
http://frigidaireservicetips.co..._TumbleActionWashers.pdf
