When I turn the dryer on, on reg. heat it runs for a few mins. then stops. If I run it on cool it will run forever. Do I need a Dryer thermal fuse?
Sounds like it could e a problem with the cycling thermostat; but it would be a good idea to replace all the thermostats and thermal fuse at once. Part number: AP3131939[PART]
'); return false; " style="text-decoration:underline;" href ="http://www.appliancepartspros.com/partsearch.aspx?pn_='); return false; " style="text-decoration:underline;" href ="http://www.appliancepartspros.com/partsearch.aspx?pn_=AP3131939[PART]" target="_blank">Part number: AP3131939[PART]
" target="_blank">Part number: '); return false; " style="text-decoration:underline;" href ="http://www.appliancepartspros.com/partsearch.aspx?pn_=AP3131939[PART]" target="_blank">Part number: AP3131939[PART]
" target="_blank">
; return false; ) Part number: AP3131939[PART]
" border="0" alt="Part number: '); return false; " style="text-decoration:underline;" href ="http://www.appliancepartspros.com/partsearch.aspx?pn_=AP3131939[PART]" target="_blank">Part number: AP3131939[PART]
" title="Part number: '); return false; " style="text-decoration:underline;" href ="http://www.appliancepartspros.com/partsearch.aspx?pn_=AP3131939[PART]" target="_blank">Part number: AP3131939[PART]
