sarah01
#1 Posted : Sunday, June 8, 2008 8:22:26 PM(UTC)
sarah01
my stove beeps and _F _1 appears on the screen what should i do
abadfish66
#2 Posted : Sunday, June 8, 2008 9:38:22 PM(UTC)
abadfish66
[LIST=1]
  • Disconnect power to stove
  • Gain access to the back of the clock (electronic range control or ERC).
  • Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  • Make sure everything is clear and will not short out when power is turned back on.
  • Turn power back on to stove.
  • Watch for the F1 and listen for the beep.
  • If you get the F1 and beep, replace the ERC.
  • If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.[/LIST]
  • Users browsing this topic
