jissber
#1 Posted : Monday, April 5, 2010 9:06:47 PM(UTC)
jissber
iHAVE A SAMSUNG MODEL RS2630SH AND I NEED THE DEFROST ELEMENT OR DEFROST HEATER, I CAN'T FIND THE PART NUMBER OR ANYPLACE THAT CAN GET IT FOR ME.
I REPLACED THE MAIN BOARD AND THE DEFROST SENCOR BUT THE FREEZER STILL FREEZES UP IN A FEW DAYS.
I FIGURE IT HAS TO BE THE DEFROST ELEMENT.ANYONE THAT KNOWS THE PART NUMBER TO DEFROST ELEMENT OR WHERE I CAN BUY ONE PLEASE LET ME KNOW.
THANK YOU
#2 Posted : Tuesday, April 6, 2010 2:59:00 AM(UTC)
Replacement parts for RS2630SH models | AppliancePartsPros.com
Check out Item 19 in Section 3.
Note: It would be best to check it with a meter as it may also be the defrost thermostat, Item 13.
Cannot say exactly what it should be but they are usually around 20 ohms.
The thermostat should be 0 ohms (closed) when frozen. It must be frozen as it opens just above freezing.
jissber
#3 Posted : Tuesday, April 6, 2010 6:52:30 AM(UTC)
jissber
Thank you so much ,i thought I would never find the parts,your answer did the trick ..
