Pump runs. Soliniod activates. Flapper intact inside pump housing. Drain hose clear (took off of air check blew back into dishwasher} tried to drain at that point Water barely came out, found small plastic ball inside d/wshr. Not a check ball from valve? pulled screen base of inside. holes clear This d/wshr has power tower. Pulled pump from unit everything seems normal there WT*? pump adgitates normally when in clean cycle but won't drain off. I do apartment maintenance 23 years now. this ones got me stumped!
Cannot find a parts breakdown to exactly match your unit but here are some units in that series. I am using the 00WW for reference. Replacement parts for GSD4000N0066 models | AppliancePartsPros.comYou could try draining it into a pail. This will check if the plumbing drain is clogged. Just be sure to hold the hose securely in the pail and put a towel over the pail so water does not splash all over. A common place for it to plug is where the hose fits over the fitting into the plumbing drain. Also could be the piston & nut (Item 564 in Section 2). This is under the cover at the back inside of the tub. It unscrews. Usually this just leaves some water in the tub after a drain cycle but perhaps it is totally shot. It has to seal when draining or the water is directed back into the tub instead of out the drain hose. |
THIS FORUM IS DEAD!!!!!!! |
Yep ran the hose into a pan and the water just barely comes out. blew back into hose and you can hear it 'girgul(sc)' inside. Like I said and I've seen one other post here, that there was a small,3/4 inch, plastic ball inside d/w. Could this be part of a check valve?
I do not believe that a plastic ball is used in this type of pump. |
