JEANNIE
#1 Posted : 18 years ago
JEANNIE
The Only Thing That Works Is The Cooktop..
Admin / APP Team
#2 Posted : 18 years ago
Admin / APP Team
Rank: Administration
Groups:
Is the clock dead?
JEANNIE
#3 Posted : 18 years ago
JEANNIE
No The Clock, Timer, Nothing Works Except The Stovetop
JEANNIE
#4 Posted : 18 years ago
JEANNIE
yes the clock is dead
Admin / APP Team
#5 Posted : 18 years ago
Admin / APP Team
Groups:
If you know how to use a voltmeter, see if you get 110 volts to the clock (there is really no other way to check, other than just taking a guess).
If the clock gets 110 volts, the clock is bad (click for replacement clock), otherwise it's probably one of the safety thermostats on the back of the oven. This is not an easy job. The thermostats are mounted on the back wall and to check them the oven will have to be removed.
JEANNIE
#6 Posted : 18 years ago
JEANNIE
Just So Everyone Will Know, It Wasnt The Clock/timer/electronic (for 156.00) It Was A Sensor Probe (easy To Install) 28.62 Thanks For The Help.
Admin / APP Team
#7 Posted : 18 years ago
Admin / APP Team
Groups:
Hmm. That's odd. If the sensor was bad, the clock would still display time or usually an error code. In other words, a faulty sensor does not cut power to the clock...
Either way, I'm glad it's fixed (wasn't trying to sell you a new clock :)).
Oven does not work but no fault codes? (Oven Repair (including Ranges and Cooktops))
by Ruby roars 10 years ago
Kenmore Elite Electric Range - lower oven does not work after "self cleaning" cycle (Oven Repair (including Ranges and Cooktops))
by AKJim 10 years ago
Oven does not work; everything else is fine (Oven Repair (including Ranges and Cooktops))
by 9hackler 10 years ago
Upper oven does not work (Oven Repair (including Ranges and Cooktops))
by billhoch77@yahoo.com 11 years ago
Whirlpool oven does not work but burners on top do. (Oven Repair (including Ranges and Cooktops))
by formula2fast 12 years ago
electric oven does not work (Oven Repair (including Ranges and Cooktops))
by pawpawrick 12 years ago
Oven does not work (Oven Repair (including Ranges and Cooktops))
by smodes 13 years ago
whirlpool oven does not work (Oven Repair (including Ranges and Cooktops))
by Alketa 14 years ago
kenmore oven does not work cooktop works (Oven Repair (including Ranges and Cooktops))
by voles 14 years ago
Oven does not work after cleaning (Oven Repair (including Ranges and Cooktops))
by mzarahemla 14 years ago
Oven does not work/heat (Oven Repair (including Ranges and Cooktops))
by karenlu 14 years ago
by esauseda 14 years ago
Oven does not work! Frigidaire/Electrolux (Oven Repair (including Ranges and Cooktops))
by justbarbie 14 years ago
Oven Does Not work UUUGH (Oven Repair (including Ranges and Cooktops))
by Puwata 15 years ago
Viking dual fuel range oven does not work (Oven Repair (including Ranges and Cooktops))
by Ren10 15 years ago
