Frigidaire front load washer won't spin or agitate. I did the diagnosis from the tech sheet inside the washer and everything checked out fine except the last step, where it says if you get about 6 ohms it is the spin control board. I replaced the spin control board($220.00) last night and did 2 loads of laundry, no problem. Put another load in this morning and it won't agitate or spin. It pumps out water no problem, just will not agitate or spin. What should I try next. Thanks for your reply.
Recheck your connections on the board you replaced, could be a connection that worked loose.
Thanks, I'll give it a try tonite.
Retried the connections, same results, no spin or agitate. I went through all of the diagnosis steps again, the only test that was different was that I did not get the 6 ohm on the final test, it was 0. Is there any connections that are typically a problem with this model or is there more trouble-shooting you can help me with. I am pretty handy, but there are limits. At what point do I throw in the towel and either get a service person or get a new machine. Thanks for your reply.
