I came home from work on Monday, to find the carpet in the laundry room in front of the washer damp. It's been several days since the washer has been used, so I'll have to run a cycle to get the water flowing. If it is a slow leak, not a gusher, were should I start looking for it? I have looked at a few of the threads on various models, for general information. However, their is none on the G.E. I have never worked on one before so any information would be most helpful.
Remove the washer front panel ( has two retaining clips at top) and check for leaks during run. If ok, you may have a inlet hose leaking.
