made ice intermittenly for a while then quit alltogether. replaced the pump motor for the water feed. the water works for the filtered water but nothing from the ice maker. what is next to replace??? any pointers would be greatly appreciated. tim
Groups: Expert
Check the fill tube that feeds the water into the ice maker. Often, if the water valve, not a pump, previously failed, it can cause the fill tube to freeze solid with ice. Unless you remove this ice, the ice maker will not receive any water.
