Both fans run, but compressor won't start. what do I check to pinpoint the bad part? Thanks in advance for your help!
Dale:)
pull relay off compressor and shake it if sounds like sand moving around or rattling then replace
Originally Posted by: manduxe  pull relay off compressor and shake it if sounds like sand moving around or rattling then replace Removed the "overload" shook it, and it rattles... Now where do I get one??:confused:
call app at 877-477-7278 they should help you with part you need
