lambchops
#1 Posted : Tuesday, March 30, 2010 10:06:18 AM(UTC)
lambchops
My washer has been doing this for some time, but has really become a problem recently. I push the button to start the cycle and I don't hear the door lock "click". Instead, I hear a series of small sounds and then the error code F/dl which I've read is the door lock error code. How can I fix the problem? Please Help!
wmckin7
#2 Posted : Thursday, April 15, 2010 4:54:17 AM(UTC)
wmckin7
I have a different model ghw9150, Try unplugging the power for several min.
I am still having the issue but it happens a lot less, The other thing I tried was reseating the connections to the MCU/CCu :)
busaboy
#3 Posted : Wednesday, May 26, 2010 4:37:53 PM(UTC)
busaboy
i have the same problem with my whirlpool dishwasher. reset conn and it sometimes works. ive checked voltage at the doorlatch mech. i have taken apart the door latch and the contacts look good and the solenoid seems to ohm out ok. i really hope its not the main control unit. does anyone know where to get parts cheap
