wolfman62
#1 Posted : Wednesday, June 4, 2008 2:46:33 PM(UTC)
wolfman62
I have a Whirlpool washer that when you try to start it the dial will spin freely. After a 3/4-1 1/4 spin it will engage the gears and allow you to set it for the wash. Is it the dial or the timer that needs to be replaced?
#2 Posted : Thursday, June 5, 2008 2:12:37 PM(UTC)
Most likely the problem is a bad timer and usually it happens if the timer has been turned CCW.
- The part number for the timer is AP3607885
Here are the break down diagrams for the Whirlpool washer Model LBR5133AW0
