mikehartwig
#1 Posted : Tuesday, March 30, 2010 1:43:32 AM(UTC)
mikehartwig
The dryer will run then just stop with a load in it
You can startup the dryer and it will run OK
is the wife overloading it
magician59
#2 Posted : Tuesday, March 30, 2010 7:12:55 AM(UTC)
magician59
If it stops in the course of a cycle, you either have a motor that is overheating, or a timer issue.
An overload may also cause the door to be bumped open.
