My fridge is getting hot very hot along the outside of the fridge. The unit is a side by side. The condenser was dirty so I cleaned it . I noticed the fan at the condenser never was running. I replaced the condenser fan motor still doesn't come on. I ran the fridge for 1 or 2 hours and she got hot again around where the doors seal to the unit. Could I have a bad thermostat on the board? Has anyone else had this problem. She is cooling and freezing just getting hot where you can smell it a little. Compressor gets hot hot hot.
I will answer my own question. It was the main board failing! Replaced and it works!!!
