loads up washes,but wont drain.no glogged hoses,gota new pump.still same problem.maybe a relay switch,idont no.maybe somebody can stear me in the right direction.i would love all input. TY VM curtdog46
By pass the lid switch and see if that fixes things.
fills up with water agitates,will not drain, or advance,dead in the water. i say timer switch.i could be wrong. but i checked pump,hoses for any clogs.
If the motor fails to run in spin, you have a bad lid switch.
can you run down how to bypass the lid switch? thanks
