My Maytag Washers Constantly Stops, Then I Push The Start Button And It Will Run For Awhile, Then Stop Again... Push The Button Again, Etc.
Could be a bad main control board; or a bad motor drive. You should find a tech sheet folded up, inside the console. It has a diagnostic routine you can run on the machine.
THANK YOU.....WILL GIVE IT A TRY...nicmalou
