talktomeh
#1 Posted : Sunday, March 28, 2010 9:07:37 AM(UTC)
talktomeh
Kenmore freezer compressor never shuts off
FridgeDoctor
#2 Posted : Sunday, March 28, 2010 6:44:41 PM(UTC)
FridgeDoctor
Groups: Expert
But how are the temperatures, too warm, too cold, just right? What are your control settings set at? what is the maximum setting?
talktomeh
#3 Posted : Sunday, March 28, 2010 7:16:30 PM(UTC)
talktomeh
It is a kenmore upright freezer its not to warm or too cold, seems to be just right. It has 5 setting I have it set on 1 and the compressor run continously, I turned it to off and the compressor shut off and I turned it to the lowest setting an about 10 min later the compressor came back on and just does not shut off.
FridgeDoctor
#4 Posted : Sunday, March 28, 2010 7:51:09 PM(UTC)
FridgeDoctor
Groups: Expert
the fact you have it turned down to 1 is not right. it should be at 3. secondly, since it only shuts off right when you shut it off, and not simply when you turn the control to a warmer setting, tells me that cold control is bad. I cant give you a part number because the model number you listed does not come up.
