I have a Wolf Model DF304. I was just starting to cook on a burner and went to turn on a burner when the fan on the oven started. This is NOT the two convection fans but the cooling fan that draws the air from the front of the oven above the door. The oven was cold and so was the burner. When I go to turn on the oven either regular or convection the timer/clock readout says Err03 after 30 seconds and does not heat up. The fan continues to run and I don't want it to burn out so I have turned off the power at the electrical box and waited for 2 hours hoping it would reset and stop running but no such luck. Please can someone help me??? I'm afraid this is going to be an expensive repair. I need to keep this going for a few more day until I finish my homemade Easter Eggs! June
When I turn the oven on to clean, it said HOT on the knob, then I remembered that I haven't used the oven since I cleaned it. I ran a 4 hour cycle to clean it. I'm afraid the c board is fried! I am getting worried that there will be NO Easter eggs this year, coconut, fudge, rocky road, pbutter, mint fudge and cherry nut fudge. My neigborhood will be sad! Can anyone help??? Wolf may be a great stove but I've already spent $2,200 in repairs and it is less than 4 years old!
