thanks, gene... i'm gonna try to get the parts immediately. i'll test the switches first, that's for sure. meanwhile, is it safe to use the microwave for now? thanks again...
It's better not to use it until it's fixed.
Can someone point me to diagrams or instructions on Removing parts needed to get to the door switches. I can't get link to work. Thanks ron
Hi, Ron.
What is the complete model number of the microwave?
kenmore 40185053210 I have 3 switches the 2 upper ore Normally open the bottom one seems to be normally closed. when i make the switch it doesnt completely go open. it always seems to read some amount of continuity in the switch. So I ordered the switch from your sight last that is normally closed. Really appreciate your reply and would still like to see some diagrams or something of that nature. thanks ronnie
Per the description on the problem, the cause is a faulty switch which should be Normally Open (very top one). The Normally Closed switch is the monitor switch and is not connected to this problem. The Normally Open switch Part number: AP4044834
Good luck. Gene.
