My washing machine belt broke. Does the motor continue to run in one direction, because I can rotate the washer driven pulley about a revolution and then back again. I don't want to just break another belt. If so could I have an electrical problem?
Originally Posted by: james3  My washing machine belt broke. Does the motor continue to run in one direction, because I can rotate the washer driven pulley about a revolution and then back again. I don't want to just break another belt. If so could I have an electrical problem? Turned out the clutch bearings were rusted solid.
