Ironhead38
#1 Posted : Wednesday, March 24, 2010 9:44:01 AM(UTC)
Ironhead38
makes this buzzing noise when you press the start button and continues to buzz while it's drying. works fine other than the noise.
Thanks David
magician59
#2 Posted : Wednesday, March 24, 2010 10:34:14 AM(UTC)
magician59
This could be vibration, caused by a broken weld.
Ironhead38
#3 Posted : Wednesday, March 24, 2010 11:34:49 AM(UTC)
Ironhead38
Hey Thanks Magician ill check that out. but now after the dryer runs for a while and it finishes the cycle it wont start back up for another load.
could it be a bad switch?
Ironhead38
#4 Posted : Saturday, March 27, 2010 4:58:20 PM(UTC)
Ironhead38
bumpplease
magician59
#5 Posted : Saturday, March 27, 2010 5:31:35 PM(UTC)
magician59
This sounds like a blown thermal fuse or high limit thermostat. They will open when the dryer overheats. The most common cause of this is clogged or restricted ventilation. You'll need to check the thermostats and the thermal fuse for continuity and replace the one (or better, all of them) that has none. This is a lot more common than a switch; however, as part of your diagnosis, you'll also want to check the door switch for continuity.
Ironhead38
#6 Posted : Saturday, March 27, 2010 5:43:57 PM(UTC)
Ironhead38
ok thanks for the reoly
