kornie
#1 Posted : Tuesday, March 23, 2010 10:51:28 AM(UTC)
kornie
This Maytag dryer makes a thumping sound when first loaded with wet clothes.As the clothes start to dry, the thumping diminishes. It stops when they are completely dry. Any ideas? Also, if possible, any special procedures on taking this monster apart? Your help is greatly appreciated! Thanks.
#2 Posted : Wednesday, March 24, 2010 2:30:00 AM(UTC)
Replacement parts for MAYTAG LDG9314AAE Dryer - Gas | AppliancePartsPros.com
This should help you get the job done
http://www.servicematters.com/maytag_library/docs/16008714.pdf
Thumping is often one of the rear support rollers (see Item 21 in Section 8 of the parts) has a flat spot.
As the unit runs the rubber softens and the flat spot along with the thumping disappears.
While you have it opened up you may as well check the belt, drum seals and glides, idler wheel etc. for wear and replace as necessary.
Also give the interior a good cleaning including the blower wheel.
Not a bad idea to also clean/check your vent system.
Basically an overhaul.
kornie
#3 Posted : Wednesday, March 24, 2010 12:40:40 PM(UTC)
kornie
Thanks for your help. I will check out the links and then tear it apart. I will let everyone know how things work out. It sure is nice to have people willing to help.
