mjackobs
#1 Posted : Friday, May 30, 2008 1:06:33 PM(UTC)
mjackobs
Hi --My ge frige was building up major frost, the board and the heater assembly were out so I ordered them from you guys (order#374188). the new board is slightly different from the one I pulled. It has a few more plug ins and a few more transistors. All of the plugs I need are there, but does it need to be the exact same board? I received part #wr55x10552. thanks for your help. Mark
abadfish66
#2 Posted : Friday, May 30, 2008 1:54:04 PM(UTC)
abadfish66
That is the correct board, they manufactured the new boards to fit in a number of refrigerators, so it will have more things on it. Make sure you look at the directions with the board, there is a wire that must be cut on some models, compare your wiring to the picture on instructions.
