There is a very horrible grinding noise coming from inside. Sounds like rocks or ball bearings grinding together etc. Is this someting I can fix? Rick
Originally Posted by: Rick08  There is a very horrible grinding noise coming from inside. Sounds like rocks or ball bearings grinding together etc. Is this someting I can fix? Rick it sounds like you have lost the bearings on one of the rollers that the drum rides on. you can get a kit that replaces the rollers the belt and the cloth bearing.
