Washer starts, then stops. Must be reset and then it runs again then stops. Will do this 5-6 times to finish a cycle. Screens are clean and water supply is adequate
:mad: Mines did the same thing until it stop working anymore. I called in a repair service and they said it was the door switch. I had only had the machine for 19 month, using it about 3 times a month!
