jefflisa2
#1 Posted : Sunday, August 26, 2007 7:31:15 PM(UTC)
jefflisa2
I have a front load washer, and right now it has water in it, and it won't do anything. When I checked on the problem, this is what I discovered.
The door lock light turns on when it is in a cycle, but doesn't do anything. No spinning, draining, or filling.
Other than that, if the timer is in the off position, the light turns off. I think this might be the lid switch, does anyone else have any ideas?
Thanks.
Jeff Chapman
