The dishwasher starts and stays in the wash mode. The soap dispenser door is not latching and the water is luke warm when I open the dishwasher. Is there a trouble shooting program to determine the problem? From reading other posts, it sound like it may be the bad solder joint on the control module. Ideas on how to fix the problem would be appreciated.
Opened up the control board and found a bad solder point on the board. Repaired it and the first cycle ran fine with plenty of hot water. Learned about the fix from an earlier post. Let's hope this solves the problem and it lasts.
