How Do I Get The Belt Bak On After Its Break
First make sure the belt is routed around the drum and forward of the drum groove with the flat side against the drum. Remove the back panel and route the belt around the idler pulley and motor. You will find there is only one way of routing that will provide proper tension on the belt.
