erikd
#1 Posted : Saturday, March 20, 2010 4:54:56 AM(UTC)
erikd
Hello,
My Bosch refridgerator is 3 years old. The ice maker output is low. Upon further inspection only 6 of the 10 cube compartments is filling with water. What I have observed is the following. After the ice tray is dumped and the tray is returned I hear the water valve turn on but do not see water come out of the supply tube for a second or two. Then water comes out to fill the tray. Then I hear the valve turn off the water stops imediately. I usually see a small peice of ice come out of the tube with the water. It's no where near the diameter of the tube so I doubt it's a clog. Is there an adjustment for the amount of water supplied to the ice tray? The water pressure looks from the water dispenser appears to be as strong as it ever was.
erikd
#2 Posted : Thursday, June 9, 2016 8:42:23 AM(UTC)
erikd
I'll answer my own question again. Turns out there was a small leak in the supply line to the ice maker. This slow leak ended up the condensate pan and would evaporate. It was enough drain the supply line between the ice making cycles. The extra water required to re-fill the supply line is what caused the low ice output. Thanks to all that replied :rolleyes:
